Old 08-24-2014, 04:02 PM   #43 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Originally Posted by CargoBoatTails View Post
Well bigger tires can cause premature wheel bearing wear and damage wheel wells, especially if you go wider. For instance,
if you have a 245/45/17
25.7 inches diameter, 23lbs weight
you shouldn't go to a 255/45/17
26.1 inches diameter, 25lbs weight
, you should go to a 235/50/17
26.3 inches diameter, 26lbs weight
kind of like Porsche does now and Lotus use to.
WTF!!!????
you say that bigger tires are BAD, then recommend bigger and heavier tires???
are you saying that PORSCHE changed tire sizes to a larger tire?
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
