Originally Posted by Cobb
Alot to take in. I do have ceramic brakes with cross drilled slotted rotors, so I got braking covered.
I want something taller to give a higher final drive and hopefull more mpg. I think the size I was looking at was like a 11% increase in outer diameter or 1.5 inches 25.5 vs 24 inches. Since I cant find anything with a higher aspect number, the middle number I was going wider.
I notice the utqg was below 560, which is what I currently have. Is the utqg code all that important? I was looking for a higher code as I believe that means more traction. Looks like the max psi is less.
Old Mechanic, never had kumo tires and then Id need 13 inch rims. Its a tight fit with the 15 inch rims for the front rotors.
Sounds like the 155/80R15 by BFG.
