Old 08-24-2014, 10:24 PM   #11 (permalink)
Old 08-24-2014, 10:43 PM   #12 (permalink)
CargoBoatTails's Avatar
Originally Posted by whatmaycome14 View Post
Where are you finding 155's?! The skinniest tire I could find was 175...
I would LOVE to have skinnier tires.
135R13 Vredestein
Glad to help figure out tire sizes for your vehicle.
The Following User Says Thank You to CargoBoatTails For This Useful Post:
ME_Andy (08-26-2014)
Old 08-24-2014, 10:48 PM   #13 (permalink)
Originally Posted by Cobb View Post
Alot to take in. I do have ceramic brakes with cross drilled slotted rotors, so I got braking covered.
I want something taller to give a higher final drive and hopefull more mpg. I think the size I was looking at was like a 11% increase in outer diameter or 1.5 inches 25.5 vs 24 inches. Since I cant find anything with a higher aspect number, the middle number I was going wider.
I notice the utqg was below 560, which is what I currently have. Is the utqg code all that important? I was looking for a higher code as I believe that means more traction. Looks like the max psi is less.
Old Mechanic, never had kumo tires and then Id need 13 inch rims. Its a tight fit with the 15 inch rims for the front rotors.
Sounds like the 155/80R15 by BFG.
Old 08-24-2014, 11:14 PM   #14 (permalink)
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
Since you're going to do mainly highway, look more at the aero part of it than weight. Most tire rack superlights are open designs thats will be poor at speed. A steel with a smooth cover will ride slightly worse, but will give better mpg.
Shooting for 600 miles of range at 65-70 mph out of a vx.
Old 08-25-2014, 12:11 AM   #15 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
http://www.tirerack.com/tires/tirete....jsp?techid=48
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 08-25-2014, 12:39 AM   #16 (permalink)
Old 08-25-2014, 12:42 AM   #17 (permalink)
Old 08-25-2014, 09:44 PM   #18 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
185/65R15 vs 165/80R15 (kuhmo powerstar)
I was looking at Durun 185/80R15 light truck tires but went with used 205/70R15 for cheap.
205/70R15 tires mounted (205/75R15 too big):
- Tony
Old 08-25-2014, 11:08 PM   #19 (permalink)
Old 08-26-2014, 12:01 AM   #20 (permalink)
