Old 08-25-2014, 06:37 PM   #19 (permalink)
bs25942
A.J. - '04 Honda Civic LX
90 day: 41.47 mpg (US)
bruce - '08 Kawasaki Ninja 650 R
90 day: 46.52 mpg (US)
Big Blue - '09 Ford F-150 LX
90 day: 17.33 mpg (US)
dr - '13 Kawasaki DR650
90 day: 55.32 mpg (US)
Ok for now I am done. I put the foam over the frame and held it down with zip ties and bolts. I then fiberglassed over it and that's when disaster struck, for the left side anyway. The resin fumes got under the foil and ate away at the foam over a large area on the side. I cut it open and sprayed some Great Stuff and made it look as good as possible before taping it back down. I then taped the edges and painted everything. I plan on redoing it in 6-12 month with foam sandwiched between coroplast. The urethane foam is too stiff to work with without cutting and gluing it together so no more fiberglass...it was expensive anyway. I am thinking the corofoam sandwich should be very strong and stiff. I have only driven it 90 miles or so but it seems likes it is doing the job. It will take a while to tell how effective this iteration is.
ID:	15673   Click image for larger version
ID:	15674   Click image for larger version
ID:	15675   Click image for larger version
ID:	15676   Click image for larger version
The Following 6 Users Say Thank You to bs25942 For This Useful Post:
aerohead (08-25-2014), California98Civic (08-25-2014), MetroMPG (08-25-2014), redneck (08-26-2014), t vago (08-25-2014), whatmaycome14 (08-26-2014)
