Originally Posted by mcrews
to add to Mech, the spinning weight is 3-4 times more than static weight. SO 5lb at each wheel is 15-20lb.
Unless you are spending a lot more money, I would look to reduce weight.
No it's not 3-4 times more than static weight, it's less than 2x because physics.
Originally Posted by arcosine
The weight inertia is not as important as some claim, the bigger tires turn slower, and the engine turns slower. Besides you have a hybrid, the inertia energy is recovered.
Only partially. Plus hybrid systems are limited in their regen power, so the more weight you add the less energy you can recover overall.
