08-26-2014, 02:16 AM
#21 (permalink)
Arcosine! You are the one with the front skirts! I remember seeing that when I was new to the site, but I have not been able to find it since!
Did you redo them?
08-26-2014, 08:33 AM
#22 (permalink)
Originally Posted by mcrews
to add to Mech, the spinning weight is 3-4 times more than static weight. SO 5lb at each wheel is 15-20lb.
Unless you are spending a lot more money, I would look to reduce weight.
No it's not 3-4 times more than static weight, it's less than 2x because physics.
Originally Posted by arcosine
The weight inertia is not as important as some claim, the bigger tires turn slower, and the engine turns slower. Besides you have a hybrid, the inertia energy is recovered.
Only partially. Plus hybrid systems are limited in their regen power, so the more weight you add the less energy you can recover overall.
08-26-2014, 10:01 PM
#23 (permalink)
Master Ecomadman
I got cheap used tires, well free actually, and put them on to see how they fit and drove.
- Tony
09-03-2014, 06:03 AM
#24 (permalink)
09-03-2014, 02:06 PM
#25 (permalink)
Uber Geek
Mr. Scary - '07 Ford Mustang GT Race Car The Truck - '12 Ford F-150 Scab EcoBoost FX4 The 5.0 - '12 Ford Mustang GT Vert Brembo Premium Da Foci - '14 Ford Focus SE
Originally Posted by Cobb
Is wheel weight all that important?
Short answer, yes.
I've done testing on a inertia dyno that showed repeatedly when I swapped a lightweight wheel on (motorcycle) it would pick up power.
09-03-2014, 03:53 PM
#26 (permalink)
Originally Posted by sqidd
Short answer, yes.
Yea but I think the wheels of a motorcycle are a bigger proportion of the total vehicle mass.
Anyhow lighter wheels are worth it for just the ride quality and improved acceleration. In terms of dollars spent per pound lost, they're also one of the better values out there.
09-03-2014, 04:15 PM
#27 (permalink)
Uber Geek
I see what you're getting at. And there may be some truth in there. But power at the contact patch is power at the contact patch.
09-03-2014, 04:21 PM
#28 (permalink)
The wheels aren't sapping power, they're just extra mass that have to be accelerated. Lighter wheels does the same thing for you as losing weight on the rest of the car, except because they spin you get a bit of bonus.
At steady state cruising they don't increase or decrease power usage other than their contribution to rolling resistance.
09-03-2014, 04:23 PM
#29 (permalink)
Uber Geek
Correct, but the OP said he was doing a lot of stop and go driving.
The Following User Says Thank You to sqidd For This Useful Post:
09-03-2014, 05:48 PM
#30 (permalink)
