Well, if it helps you feel better, just think of it as a civic with a lift kit and belly pan
I'm encouraged that if I kammed the back I could hit 45 mpg at higher speeds due to longer glides. Off with the side mirror! Just need to find the will to start fiddling with the door panels on a new car.
