My idea was that the two bottom bolts would be replaced. I'd cut two newer 17" bolts, drill 2 holes on each side of the angled aluminum and thread the bolts through that. This way the bolt goes through one piece of angled aluminum, through the batteries, then out the other side through the other piece of angled aluminum. I'd put a series of nuts on the inside to secure the batteries from sliding around. Right now they have the ability to slide from side to side and that might be dangerous when riding and turning. I'm going to drill those this weekend. After that's all secure it should be good to wire.
