Old 08-30-2014, 05:38 PM   #10 (permalink)
Cobb
Im wondering if the "wet" or fuel added would negate any fuel economy using NOS over forced induction? Is the fuel used during the shot the same used for a turbo application? At least with the NOS you can use a switch to arm it, rpm range or a progressive setup where as the turbo is always on.
Ive toyed around with the idea of a chemical intercooler or methanol water injection or using that in place of the fuel when spraying NOS so you keep your MPG?
I think a wet shot of nitrous would be better.
