Old 09-01-2014, 08:02 PM   #12 (permalink)
02ws6
Carry the block to a machine shop where they can check each bore. I'm certain a fresh crosshatch will be necessary. Use ARP hardware when possible. My factory rod bolts stretched when reassembling mine. Also have the cylinder head checked. Valve stem seals replaced, guides checked. Polishing crank journals is also a good idea.
