Old 09-01-2014, 09:56 PM   #509 (permalink)
NeilBlanchard
Yes, it has that stuff on it. Good sticky tape can lift it off, or you pick at it with your fingernail. The only good aspect is that I can remove marked lines after the fact.
I have a better idea than drain holes - a sloped panel "roof" inside the strake to shed water out. Even with drain holes, in the winter it is going to freeze - and that would not be pretty.
I got the left side more or less to the same level as the right. I cut off the excess fabric at the top, as well.
aerohead (09-27-2014)
