Old 09-02-2014, 06:02 PM   #16 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Daox, is there room to direct drive the pump if you have a physically smaller motor?
If the pump you have is overkill, would a smaller pump be better? (Whether it's direct drive or belt drive.) I'm thinking something like a garage door opener or a gate opener.
Can you source a new(ish) motor from a Toyota hybrid from maybe a JY for cheap?
Can you modify an electric A/C compressor to drive the water pump or even be the pump itself?
Just throwing ideas out, maybe something will stick...
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
The Following User Says Thank You to jeff88 For This Useful Post:
Cobb (09-03-2014)
