Old 09-02-2014, 07:06 PM   #18 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Is there a way to measure how fast the pump is currently spinning... maybe with an adjustable strobe light? At that point you could size a motor properly.
Is the Tercel engine available for any other models that happened to have the knock sensor? Does JDM or other international versions come with the knock sensor? Actually come to think of it, does it even need to be from the same engine?, I know nothing about knock sensor operation.
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
