Old 09-03-2014, 07:34 PM   #20 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by spacemanspif View Post
If you are tearing apart the cooling system make sure the flush the radiator backwards. If the previous owner used some stop leak it could have clogged the rad and might contribute to your over heating issue. Heater core should be back flushed as well. Both can be done without pulling the thermostat which you'd have to do to flush the block. All this is under the assumption that you are flushing with a garden hose and not using a rad flush type additive product. Congrats on the purchase!
I'll use a garden hose to flush the radiator, how do I flush the heater core...? As a matter of fact, how do I flush the system at all? Haha.
Anyway, I took my car to the tire place and they don't fix studs there, so it will have to get done tomorrow. The vibration is 100% gone. I was right in assuming the non-balanced tire was causing it. I actually gained mileage with the bigger tire oddly enough, but I'm having to use more assist to get up to speed. I'll get RE92's once I get an alignment done and the overheating issue addressed.
On my way to the tire shop, it's 100F outside right now, and the coolant never got about 203F. Even at taking off up a hill. Just saying.
