Old 09-03-2014, 09:18 PM   #3 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by johnlvs2run View Post
Why do you feel the sensor reading is a better indicator?
Does the .015 reading indicate fuel passing through, or fuel still left in the line?
Because the ultragauge is dependent on the sensors and there is no FE sensor. So therefore the 999.99 mpg number is a UG calculated guess. The sensor is directly reading the exhaust and reporting out voltage according to what it finds. Given how many times the engine turns in a second at 1500 or 2000 rpms, I can't imagine residual fuel would last more than 1 or 2 seconds. But this can go on continually over 10 seconds, and not at 0.015, but at numbers like 0.6 and such. There's no way that at a 0.6 O2 voltage reading from the sensor the FE could actually be 999.99 mpg, is there? What do you think?
