Old 09-06-2014, 05:46 AM   #6 (permalink)
josemapiro
Originally Posted by tvcsantos View Post
hi,
I still have to read more about the connections, and buy an LCD and some buttons.
Tiago
Olá Tiago
Em relação aos botões, podes utilizar um sistema com 3 botões, ou 1 botão de 5 posições, que são ambos apoiados no codigo, só tens que definir qual vais usar. Tens a descrição destes dois sistemas no post do t vago, vê qual é o mais adequado para ti.
Hi Tiago
Regarding the buttons, you can use a system with 3 buttons, or 1 button 5 positions, which are both supported in the code, you just have to define what you will be using. Have the description of these two systems in the post of the t vago, see which is right for you.
José Rodrigues
