Old 08-21-2014, 04:16 PM   #1 (permalink)
mpguino & arduino mega 2560
Hi there,
I have an arduino mega 2560 laying around.
I was looking at the source code for mpguino and saw that there are two files, a .PDE and a .CPP. The PDE file says that mpguino has moved outside of arduino, what does that mean?
If it means that basically the .PDE is outdated and the .CPP is more recent, how can I compile the CPP for arduino mega 2560?
Your help would be much appreciated
Thanks
Tiago
Old 08-21-2014, 04:54 PM   #2 (permalink)
The arduino uses the atmega chips. The atmega chips can be programmed via the Arduino IDE, or via AVR studio which is a bit more nitty gritty. The Arduino IDE makes it easier for beginners and it also makes it quicker to do simple tasks. You can combine the some AVR coding with the Arduino IDE, to what extent I'm not sure. This is what was done with the MPGuino code.
Old 08-21-2014, 05:27 PM   #3 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
I pretty much re-wrote the MPGuino code. My code supports the Arduino Mega 2560. It can be found here -> http://ecomodder.com/forum/showthrea...ead-26469.html
The Following 4 Users Say Thank You to t vago For This Useful Post:
Daox (08-24-2014), Felar (08-23-2014), jeff88 (08-21-2014), Xist (08-23-2014)
Old 08-23-2014, 01:47 PM   #4 (permalink)
Olá Santos
Utiliza a versão do t vago, que funciona bastante bem e esta operacional para o Arduino Mega 2560, as outras versões não funcionam com essa placa.
Hello Santos
Uses the version of t vago that works quite well and is operational for the Arduino Mega 2560, other versions do not work with this board.
José Rodrigues
The Following User Says Thank You to josemapiro For This Useful Post:
t vago (08-25-2014)
Old 09-04-2014, 10:42 AM   #5 (permalink)
hi,
i've been busy for the last few weeks, and i hope to get some time to investigate further about mpguino.
Thanks @t vago for the 2560 mpguino code, and also @josemapiro for the suggestion, i'll look into it.
I still have to read more about the connections, and buy an LCD and some buttons.
Tiago
Old 09-06-2014, 04:46 AM   #6 (permalink)
Originally Posted by tvcsantos View Post
hi,
Tiago
Olá Tiago
Em relação aos botões, podes utilizar um sistema com 3 botões, ou 1 botão de 5 posições, que são ambos apoiados no codigo, só tens que definir qual vais usar. Tens a descrição destes dois sistemas no post do t vago, vê qual é o mais adequado para ti.
Hi Tiago
Regarding the buttons, you can use a system with 3 buttons, or 1 button 5 positions, which are both supported in the code, you just have to define what you will be using. Have the description of these two systems in the post of the t vago, see which is right for you.
José Rodrigues
