Old 09-08-2014, 05:31 PM   #10 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
Originally Posted by SilverCrown9701 View Post
I have UltraGauge. I don't slow down fast enough with my engine on in neutral. My car seems to coast for quite a long ways.
That's a good thing! If you have the time, and won't be annoying following drivers (who can't pass you), then start the neutral coast sooner. That'll save more fuel.
My car has DFCO so that's why I figured leaving it in drive would yield better results.
If you are *trying* to slow down faster than coasting in N, then using deceleration fuel cut-off in gear is more efficient than using the brakes. But coasting in N is generally more efficient than DFCO because you get off the accelerator (accel. or maintaining speed, burning the most gas) even sooner.
Also, your car only cuts fuel above a certain RPM, and possibly not at all in the lowest gears (your gauge may show you this). I recently drove a brand new Nissan 4-speed automatic that never cut fuel in 1st or 2nd gear.
Shutting off at lights worries me about extra wear on the starter and ignition.
I only know of one person who has worn out a starter while trying to save fuel, but he was shutting off at every single opportunity, including pulse & glide (automatic). Driving a Honda.
Stopping the engine when the car is stopped is worth roughly 5-10% better fuel economy in city driving, which is why auto stop/start is now becoming common on new cars (including non-hybrids).
Whether you should do it or not is entirely up to you.
SilverCrown9701 (09-08-2014)
