Thread: SUV Kammback
Old 09-10-2014, 09:58 PM   #32 (permalink)
freebeard
How well will bamboo hold up in both hot and cold weather, rain, humidity, etc.?
As well as the PVC in sunlight.
Green Building - Sustainable Products &amp Construction Materials | Cali Bamboo
Thanks to its unique composition, bamboo is naturally designed for strength...
As a result, in structural engineering tests bamboo has been shown to have...
Higher tensile strength than many alloys of steel
Higher compressive strength than many mixtures of concrete
Higher strength-to-weight ratio than graphite
But that's just my reaction to evil, evil PVC. Were it I, I'd get aluminum flashing metal and roll strips into 120° of a circle, cut the side pieces and roll the edges on a longer radius and rivet it all together. That would closely approximate the squircle.
That sounds like a technical term; I like it.
Technically, it's a special case of the superellipse.
The Squircle Is The Hottest Thing In Car Design Right Now - Jalopnik
Haha, in 3 feet, I can only get about to about 30% of a full tail based on the template, since my tail end is fairly squared off.
I felt bad when I wrote that. It was almost like a boast.
UnicycleDan (09-10-2014)
