Old 09-10-2014, 10:35 PM   #57 (permalink)
SilverCrown9701
SilverCrown9701's Avatar
SilverCrown - '01 Toyota Camry LE
90 day: 35.32 mpg (US)
Originally Posted by XYZ View Post
That won't tell you which wheel might be dragging. To check each wheel, simply jack up each wheel off the ground with the car in neutral, one at a time, and turn it by hand. If one wheel is harder to turn than the others, check the brakes on that wheel.
You could also rotate your tires at the same time while doing the check, if you are so inclined.
Ok thank you! I will try that this week and report back here.
The name "Camry" is an Anglicized phonetic transcription of the Japanese word kanmuri meaning "crown".
