Old 09-11-2014, 12:22 AM   #22 (permalink)
tyronasauras
grey panther - '02 Mercury Grand Marquis
Team Panther
90 day: 27.15 mpg (US)
Check the coolant reservoir cap. The system is pressurized and a bad cap can cause the symptoms you are seeing. Not likely, but one more thing to check. I had a problem with a car I couldn't get to cool after a minor front end collision. Burped the hell out of it, new thermostat, cleaned it. finally replaced the radiator and it worked great. 150k miles on it and I think the "bump" dislodged some crud or damaged it internally.
