Old 09-11-2014, 10:45 AM   #128 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Originally Posted by Baltothewolf View Post
[Edit again]: Now that I'm reading it again I understand what to do completely. My question about spraying fuel into the cylinders still stands however.
If you're concerned the injectors may spray added fuel before the engine stops, search on IC: there's a second, more complicated method that involves wiring the kill switch to 3 relays (which you add) on the fuel injector circuits for each cylinder instead of killing spark via a simple switch.
I didn't think it was worth worrying about. Caveat Kill Switchor.
