Old 09-11-2014, 06:12 PM   #41 (permalink)
XYZ
Originally Posted by Old Mechanic View Post
Now if you climb a steep grade like before what does it read? That's a stress test and it will probably go higher than other times. When that reading (after climbing a steep grade) causes the temp to skyrocket but there is no air bubble and the cooling system operates normally otherwise, you need a radiator.
regards
mech
Another possibility is that his cooling fan isn't coming on as it should.
The Following User Says Thank You to XYZ For This Useful Post:
user removed (09-12-2014)
