Old 09-15-2014, 08:29 AM   #614 (permalink)
basjoos
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
Originally Posted by 101Volts View Post
I'm feeling inspired to just get some junky beater car and mod it "relentlessly."
BTW, Basjoos - Have you ever considered a small-engine Diesel conversion?
At various times I have considered it (also the EV conversion), But the lean burn engine currently installed provides close to diesel-like efficiency while burning less expensive regular gasoline. Also the Honda lean burn engine installation was a much simpler and cheaper process than replacing the Honda engine/transmission with a VW diesel/transmission. Also repair work on a Honda engine repairs is cheaper than the equivalent repair work would be on a VW diesel.
I declined on doing an EV conversion at this time because of the battery range limitations and because at 70-80mpg my fuel costs are roughly equivalent at the current gasoline prices and electricity rates. Also replacing a worn out lean burn engine with a used imported lean burn engine is much cheaper than replacing a set of worn out batteries 200,000 miles down the road.
aerocivic.com
The Following 2 Users Say Thank You to basjoos For This Useful Post:
aerohead (09-24-2014), pgfpro (09-29-2014)
