Old 09-14-2014, 01:35 AM   #611 (permalink)
101Volts's Avatar
Woody - '90 Mercury Grand Marquis Wagon LS
Last 3: 19.57 mpg (US)
Brick - '99 Chevrolet K2500 Suburban LS
Last 3: 12.94 mpg (US)
M. C. - '01 Chevrolet Impala Base
90 day: 18.73 mpg (US)
R. J. - '05 Ford Explorer 4wd
90 day: 16.66 mpg (US)
I'm feeling inspired to just get some junky beater car and mod it "relentlessly."
BTW, Basjoos - Have you ever considered a small-engine Diesel conversion?
Old 09-14-2014, 04:58 PM   #612 (permalink)
5 pin sensor
Zippy - '96 Honda Civic Hx
90 day: 40.77 mpg (US)
Boring - '11 Ford Fusion Sel
90 day: 21.88 mpg (US)
Originally Posted by johnlvs2run View Post
Yes, and why did they park like that?
Dual purpose as an ecomod, the garden edging actually is being used for what it was intended in this picture, the flower bed is just behind the car in this picture
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
The Following 2 Users Say Thank You to Chrysler kid For This Useful Post:
aerohead (09-24-2014), freebeard (09-14-2014)
Old 09-15-2014, 07:48 AM   #613 (permalink)
It looks like a narrow (one lane?) road / driveway.
Old 09-15-2014, 08:29 AM   #614 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
At various times I have considered it (also the EV conversion), But the lean burn engine currently installed provides close to diesel-like efficiency while burning less expensive regular gasoline. Also the Honda lean burn engine installation was a much simpler and cheaper process than replacing the Honda engine/transmission with a VW diesel/transmission. Also repair work on a Honda engine repairs is cheaper than the equivalent repair work would be on a VW diesel.
I declined on doing an EV conversion at this time because of the battery range limitations and because at 70-80mpg my fuel costs are roughly equivalent at the current gasoline prices and electricity rates. Also replacing a worn out lean burn engine with a used imported lean burn engine is much cheaper than replacing a set of worn out batteries 200,000 miles down the road.
aerocivic.com
The Following 2 Users Say Thank You to basjoos For This Useful Post:
aerohead (09-24-2014), pgfpro (09-29-2014)
Old 09-29-2014, 10:00 AM   #615 (permalink)
I noticed your last fuel log entry for the AerocivicLB was exceptional.
1992 Honda Civic CX Gas Mileage (AerocivicLB) - EcoModder.com
Care to share...???
MetroMPG (10-02-2014)
Old 09-29-2014, 12:35 PM   #616 (permalink)
LOL, he slowed down.
regards
mech
Old 09-29-2014, 01:23 PM   #617 (permalink)
basjoos's Avatar
Probably a very good summer tank combined with pump error. I had to gas up at a different pump than I usually use. If I can gas up at my usual pump, my next tank should average out any pump error present in my last fuel log entry.
aerocivic.com
The Following User Says Thank You to basjoos For This Useful Post:
aerohead (09-29-2014)
Old 10-02-2014, 03:38 PM   #618 (permalink)
basjoos's Avatar
I gassed up today with a calculated 73mpg for this tank. When combined with the previous 96mpg tank, it calculates out to 83mpg. So the high mileage of the previous tank was a combination of pump error and higher mileage. The only change I have made in my car was to add an intake manifold pressure gauge, which makes it easier to monitor when I am in lean burn (its easier note the position of a needle rather than having to read and interpret a digital number on the SuperMID). I used the enter/exit lean burn injector pulse width jump on the SuperMID to tell where on the pressure gauge the engine leaves lean burn and could refer to the gauge after that point to monitor lean burn.
aerocivic.com
aerohead (10-03-2014)
Old 10-02-2014, 03:53 PM   #619 (permalink)
Stick a 2x4 under the left rear wheel when you pull up to the pump. Got mine to be much more consistent.
regards
mech
Old 10-07-2014, 02:39 PM   #620 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Hadn't thought of sticking a 2x4 under the left rear; not a bad idea. I try to find a pump to park at that has a slight nose-down incline.
aero mods-data-% change or Cd change ( installment # 7-Wheels/Tires/Wheelcovers/etc. aerohead Aerodynamics 5 06-04-2014 12:14 PM
[aero-mods(aft-body streamlining/boat-tails)Part-3 History/Timeline cont'd aerohead Aerodynamics 10 08-13-2010 12:50 AM
mods-data-% change or Cd change( installment#5-roofline data) aerohead Aerodynamics 3 09-26-2009 02:01 PM
Build Thread Key Postings Index Experiment. TestDrive Forum News & Feedback 7 02-15-2009 08:53 PM
Drafting and Cd reduction basjoos Aerodynamics 5 12-06-2008 10:45 PM
