So, here is a list of the available gauges for my 2001 Toyota Camry.
Which of the following listed below offer the best feedback while driving for better fuel economy???.....
Open/Closed Loop Emissions Status
Percent Engine Load
Engine coolant temperature (°F)
Short Term Fuel Trim Bank 1
Long Term Fuel Trim Bank 1
Intake Manifold Absolute Pressure (MAP) PSI
RPM
MPH
Ignition Timing Advance
Intake Air Temperature (°F)
Absolute Throttle Position Percentage
Bank 1 Oxygen Sensor 2 Voltage
Bank 1 Wide Oxygen Sensor 1 lambda Voltage
Boost Pressure, (Relative Pressure) (PSI)
Brake Horsepower 1
Torque 1 (ft lbs)
Brake Horsepower 2
Torque 2 (ft lbs)
Volumetric Efficiency
UG Battery voltage
Mass Air Flow 2, Calibrated/Calculated
Instantaneous MPG
Intantaneous Gallons/Hour (GPH)
Distance to Empty(DTE)(miles)
Time to Empty (TTE)
Fuel Level (gallons)
Oil Distance(miles)
Service Distance(miles)
General Purpose
Average MPH
Average MPG
Average Gallon/Hour (GPH)
Fuel Used (gallons)
Run Time
Distance (miles)
TRIP GAUGES
Run Time
Average MPH
Average MPG
Fuel Used Gallons
Average Gallon Per Hour (GPH)
UltraGauge Internal Temperature (°F)
SHORT TRIP GAUGES
Run Time
Avergage MPG
Fuel Used (gallons)
Average gallons/hour
Average MPH
Distance (miles)
The name "Camry" is an Anglicized phonetic transcription of the Japanese word kanmuri meaning "crown".
