Old 09-17-2014, 08:09 PM   #1121 (permalink)
dave koller
dave koller's Avatar
Originally Posted by e*clipse View Post
On another note, I really need to look into the sources of those noise pulses closer. For example, I'm doing all this on a solderless breadboard. These are known to be the worst noisiest option out there. Simply using a proper PC board with a ground plane and well designed circuitry could get rid of most of the other spikes. I would like to use through hole components so anyone could assemble them, but surface mount components do have EMI advantages. I've soldered a lot of surface-mount components in my toaster oven.
- E*clipse
P.S. - e-mail coming
On most of the breadboards I've tested in a noisy environment I have put massive numbers of .1 and .01 caps on all chip power leads as close as I can to the chips - and place them on all power lead, regulators etc... Helps so much to quench those transient spikes...
Dave ...
The Following 2 Users Say Thank You to dave koller For This Useful Post:
e*clipse (09-17-2014), MPaulHolmes (09-17-2014)
