Old 09-18-2014, 10:56 AM   #10 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
The 5MT also has a much taller top gear, and less energy is lost in the transmission. Lean burn at a given throttle opening uses something like 2/3 the fuel, so you'll see the display jump from 50 to 75MPG, but the engine output isn't the same. Lean burn, as I understand it, allows for very small power outputs while still remaining relatively efficient.
