Old 09-18-2014, 03:32 PM   #7 (permalink)
oil pan 4
But you can get 50 amps of 240 volt power, which gives you 12kw.
So is the class system based purely voltage or is there an implied wattage limit too?
Then is that voltage single or 3 phase?
If its single phase is it line to line power or line to neutral?
If its 3 phase is it delta or "wye" configured?
