Originally Posted by redpoint5
205 degrees is not overheating.
My Camry overheated a few weeks ago due to loosing all the coolant to a hole in a bypass hose. I believe it had a code for misfiring. The code for overheating is P0217, and you won't get that until at least 240 degrees.
He is seeing much higher temps than 205*, in fact much higher than even 240*
