Old 09-20-2014, 08:23 PM   #135 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Ok so I just tested the coolant system with a pressure tester and the results create even more confusion...
The pressure slowly, slowly drops when it's cold, and same results when it's hot.
This is when the engine is fully hot.
After 5 minutes.
After ~9 minutes.
13 Minutes.
~20 minutes.
I'll stop there, but you get the picture. What does this mean...? I'm so confused, I checked every hose and everything and didn't see any sign of leaking nor did I hear anything hissing.
I would also like to add this, my radiator fans kick on at 207 then kick off the second I drop to 204. Shouldn't they be staying on a little longer then that?
