Old 09-21-2014, 09:50 AM   #174 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by cowmeat View Post
Glad you got it fixed, Balto! Crazy outcome, but makes perfect sense once you found the issue.
Now we can do battle gaining mpgs while we learn to drive these things!
I have the advantage of being on basically the flattest land possible, but I do face a lot of traffic along with a lot of stop and starts. You have the disadvantage of going up the hills, but you should get infinity mpgs and a good IMA charge coming back down them.
Good luck!
You better watch out :P. Right now with cheap off brand non LRR oversized tires, worn brakes and rotors, missing belly pan under engine bay, and EGR unplugged my average commute to work is 57MPG.
I do need to know why it's pushing coolant into the recovery bottle though. This isn't something I can just ignore as I can't properly bleed the system like this.
