Old 09-21-2014, 09:33 PM   #60 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
wheel discs on, grille block under construction
All four mounted now...
I took the car up to ~110 km/h and double-checked them. All looks good.
Started on the grille blocks as well. I just used some scraps of wood to sandwich the factory grille, and screwed coroplast into the scraps:
Before...
Now:
Upper is now completely blocked. I'm going to reposition the plate to the lower right grille area, leaving a center opening about the size of the plate itself.
ID:	15898   Click image for larger version
ID:	15899   Click image for larger version
mikeyjd (01-14-2015)
