Originally Posted by Baltothewolf
Done! Lemme know if I missed any, I don't think I did. Anyway, I figured out why it was pushing water into the recovery bottle when I was bleeding it, radiator cap thar came with the radiator was bad. I put the one from my old radiator on there (OEM cap) and it works just fine now.
So what does that have anything to do with the fan and its "polarity" as supposedly being wired "backwards"? Apparently the real problem of your overheating had nothing to do with that. Did it?
I still would like to hear a truthful answer as to who butchered the original wiring and added the wire nuts.
I don't care if anyone on this forum ever gives me thanks. I'm not here to garner and reap praise. I don't care who gets the credit. I only care that the problem gets solved. That's "the bottom line".
"Success has many fathers, but failure is an orphan".
BTW, if this problem should ever reoccur, I'll still try to help you. Although I question
everything, including you,
I'm not your enemy. Please remember that.
