Old 09-24-2014, 06:21 AM   #6884 (permalink)
duncan
wiring
Hi Paul
Finally time to work on the controller -
so much stuff to do had built up while I was crook!
I have two pictures here
One has the two positions that the DC-DC can connect to the control board
(1) and (2)
Which one is it????
Other picture
I have the throttle
A funny four way cable (1)
The serial cable (2)
This one has an LED on it (3)
No idea (4)
No idea (5)
Also in on this end will be the 12v for the DC-DC
The other end has
Three power cables - to be joined together to go to motor
Four other power cables ????
What are they? - where do they go?
I'm making up a slightly different case - along with the cooling things I got from Hobbyking
ID:	15909   Click image for larger version
The Following User Says Thank You to duncan For This Useful Post:
MPaulHolmes (09-24-2014)
