Old 09-25-2014, 03:10 AM   #10 (permalink)
u.steinlechner
Measurement of fuel consumption
One method, I used to measure the furel consumtion was a turbine flow meter.
Because a turbine does not measure exact changing flow rates, I measured at constant speeds.
The test track is a flat round course, driven at early sunday morning without influence of traffic. The weather conditions were equal. With GPS, I held constant speed. Average values came through multiple measurements.
Units are metric. km/h kilometers per hour. Consumption: liters per 100 km.
It is possible to change the aerodynamic parts within 15 minutes, so the time between the test is short.
Turbine Flow Meter
(Image will follow)
Counter
Hersteller (manufacturer) B.I.O-TECH e.K.
Typ ARS 260-A
ID 2160
Mini Durchflussmesser (flow meter)
Hersteller B.I.O-TECH e.K.
Typ FCH-m-PP-LC
Messprinzip Turbine
Düse 1mm
Impulszahl/Liter 10500
Treibstoff (fuel) Shell Super Benzin
Dichte (density) 0,7684
Temperatur °C 18
Flow Meter, GPS
(Image will follow)
(Image will follow)
Serial parts and aero-kit
[(Image will follow)
Tools to mount the kit
(Image will follow)
The Following User Says Thank You to u.steinlechner For This Useful Post:
aerohead (09-25-2014)
