Old 07-16-2008, 10:02 PM   #67 (permalink)
pasadena_commut
Originally Posted by Otto View Post
Use both: Coroplast on the sides and aluminum screen near the hot places like exhaust pipes and mufflers. That will allow heat to be drawn off rather than collecting. Aluminum screen is a superb heat conductor and dissipater.
That would also electrically insulate the aluminum from the frame of the car, as long as it wasn't too wet underneath. The downside of using a different metal in the screen than in the body of the car is that it opens up the possibility of galvanic corrosion. Aluminum + iron + wet salted roads = not good.
