Old 09-26-2014, 07:38 AM   #19 (permalink)
redneck
I don't use engine off coasting but pretty much use all of the other tips to help.
You're missing the boat then, bro! EOC is the absolute easiest way to get a massive boost in mpg.
I immediately jumped almost ten mpg the first tank I EOC'ed in the Black Widow, and I was an instant convert! All I did was EOC up to all stop signs and lights, nothing crazy.
Try it for a tank and see if you ever go back to NOT doing it!
Nice job though!
Ditto...
Having a kill switch is the way to go instead of cycling the ignition switch.
Also, a kill switch will allow all of the vehicles systems to remain functional. The other big plus is not having to worry about the steering wheel locking up. A kill switch will also allow your ultragauge to remain booted up.
Just try it. Plan a short route and drive it without EOC and then with EOC.
You'll be impressed...
