I never did too many performance mods. Most were show. I did wire up 2 12 volt lights for 24 volt operation, wired up a 24 to 12 volt converter for power and went to atv tires. Batteries I went to wet lead acid as I do not fly. They charge faster and last longer. The cat I cleaned the motor and brushes, made it run better. It was full of black coal dust like. The quickie when range wasnt an issue I went to 2 u1 batteries up in the front compartment to help reduce it from wheelieing. The p200 is designed to float on the drive wheel, but that gets old fast.
