The problem isn't torque, its the car. The OBD2 port does not have access to all the sensors in the car, which is what is causing it to not read out a MPG. As far as I know, if one app doesn't work, especially one as well known one like torque, you're going to be hard pressed to find one that does.
I would recommend seeing if you can get a MPguino
2002 Jetta GLS TDI 345k+ miles, all mods listed in description 156HP, 298FT/LB
The eclipse has retired, but I still like seeing it around
