Originally Posted by Astro
Forward and reverse on a 3 phase motor.
Am i right in thinking that the controller can be asked to reverse the motor direction or you can just swap any two of the phase cables to reverse the motor direction?
Just want to make sure the default motor direction is the correct direction for the gearbox.
I don't need 5 reverse gears.
The controller can reverse by changing the phase, forward is for example A,B,C and reverse can exchange any two, say A,C,B
Not sure about Paul's code - may require a small tweak to allow either direction to be default?
