Hi Paul
Slowly getting my act together,
J5 and J6 - I assume I can simply cut them off short
I control the pre-charge and contactor in my car (gives me something that looks "technical" to do)
The LED - I was going to connect it to the external wiring thing - but I think I'm out of connectors
Is it OK to remove it? or should I mount it on the case?
What does it tell me?
The five wire ribbon cable and the PiCkit
The PiCkit has six wires - do I just ignore one of them?
Which one?
Can I connect the PiCkit through one of those external wiring things?
Now when its all together - I will send a picture
What is it set to?
Current at 5Kohms throttle?? -
Ramp speed?
I'm asking this because that PiCkit thing looks terrifying and if I can run without messing with it I will
Thanks
Duncan
