Hi Paul
That's great
I will make the second end piece with;
12v +/- power
Throttle
Both on one black connector thing
The five PiCkit connections
On the second black connector thing
The serial connector.
I think your code is fine except the temperature sensing is disabled
Do you mean the sensing for a separate gauge is disabled?
Is the current reduction for if it gets too hot active?
1000amps at full throttle????
