Old 10-02-2014, 07:23 PM   #60 (permalink)
TimV
SUVcruiser - '07 Ssangyong Kyron 2.0 XDI
90 day: 42.55 mpg (US)
SUVcruiser year 2017 - '07 Ssangyong Kyron 2.0XDI
Hybridcruiser 2023 - '13 Volvo V60 D6 AWD
90 day: 123.84 mpg (US)
I found a nice solution for the grill block. I stole the idea from the web. I searched for grill block. And i saw a picture of a prius using tube isolation to block the grill. So i used the same.
If u dont know annything about the grill block. You probably wont even recognice it
And it sits pritty flush with the surface.
I watched the temps. Max temp on slow driving. When fully warmd up. Is not higher then normal 88 -89 degrees celcius. Temps on long highway driving (40km) drafting a big rig, is not higher then normal. Outside temp is 21 degrees celcius. Intake air temp was only a 1 degree celcius higher then normal.
And another nice thing: faster warm up. Normally after 12km temps is at 70 degree celcius (temp with needle on dash at the good temperature). Now it was after 5 a 6km
Best thing yet. Cost me about 1,5 € (2$)
Drive smart, save fuel, save money, spare the enviroment
But keep having fun!
I can drift
Previous car. SUV. From 2011+ 10l/100km to 2017 5,516l/100km.
2017 without holiday: 5,397l/100km
EPA Rated average: 8,1l/100km
Current ride: plug in 285hp hybrid
EPA Rated average: 2,8l/100km
