Originally Posted by johnlvs2run
TdCRX,
Thanks very much.
If I understand correctly, your belly pan is coroplast painted black, supported by aluminum strips, and bolted to the frame. I'd like to do at least a partial belly pan, but need to find a safe way to jack up the car in my driveway. In the meantime I'll try to screw the side skirts to the molding and hope that they hold.
I have a suggestion. You could get some 2x12s that are the length of the car, make some ramps to drive onto them, and use those to raise your car so you can crawl under it...
