Old 10-03-2014, 03:18 AM   #20 (permalink)
Astro
Dreamer
Originally Posted by Astro View Post
I haven't estimated the weight of the 12v accessories battery as i am still trying to decide if i will use a small motorbike battery or some form of LiFePo4 battery. I am leaning towards the motorcycle battery as it will not require as much monitoring or charge / discharge control.
Is self quoting allowed?
I just measured the parasitic draw on the accessory battery with car all off.
I wanted to know how quickly a small motorcycle battery would be discharged with the parasitic load.
The current draw is 5.27mA.
So about 55 days to flatten a 7Ah battery to dead flat.
Maybe count on a month before the voltage drops too low to be useful for energising the contactors. If the contactors can be energised then the DC-to-DC converter will fire up and the car will be good to go and the accessory battery will start charging.
If that is correct then i should be able to ditch the massive 12.6kg (27.8lbs) standard car battery and replace it with a battery that takes up about a quarter of the space and saves over 10kg (22 lbs) in weight.
I will have to check the regulations to find out how long the accessory battery is required to continue without input from the traction battery via the DC-to-DC converter.
Checked, it has to be able to power the hazard lights flashing for a minimum of 20 minutes.
So 6 globes. (rear 2 x 21W, front 2 x 21W and side 2 x 5W) 94watts or 7.8A at 12 volts
50% duty cycle (flashing) lowers it to 3.9A averaged.
So 20 minutes should only need about 1.3Ah from the 7Ah battery
Looks like it may be doable.
The Following User Says Thank You to Astro For This Useful Post:
thingstodo (11-10-2014)
