Old 10-04-2014, 09:17 PM   #3 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Grounding the alternator's C terminal will put the alternator in the 12.5v low output mode. I keep mine there most of the time. I have disconnected the wire to the ECU and ground the C terminal manually through a resistor. The resistor might not be necessary, but I put it there anyway. I might've used a 100 ohm, I'm not sure. The alternator won't be totally off if you do this, but it won't be working as hard either. You'll want a voltmeter in the car. Running too high of an electrical load in this mode will drain the battery.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
redpoint5 (10-05-2014)
