1.DIAMETER of the tire is what is important. if you are decreasing the overall diameter of the TIRE you will hurt mpg.
2. you gain a SMALL amount with a smaller/lighter? rim. because you are moving the MASS in. Given that the tire is at least the same diameter.
3. I have increased the tire diameter on both my vehicles using the stock rims and got better mpg.
