Old 10-06-2014, 09:49 AM   #10 (permalink)
Daox
From your description, I'd start by grounding the C wire. Its the easiest thing to do. Its meant to turn the alternator on/off so a logical place to start. You could put a resistor in there to make sure you don't toast anything. You might want to measure current while you're at it to see if you need it or not.
The Following User Says Thank You to Daox For This Useful Post:
redpoint5 (10-06-2014)
