first stage vtec is the green wire "m" , middle stage vtec is the red wire "h", "wild cam" operates both solenoids together.
My jdm 37820-p2j-j62 ecu was dirt cheap on e-bay (about $70 shipped)
JDM Honda Civic D15B OBD2 vtec Automatic CVT 37820 P2J J63 ECU ECM 37820 P2J J62 | eBay
(just an example, but they do have %100 positive feedback)
Here is a walk-around of my engine (jdm d15b dual vtec w/ lean burn) - and yes, I have moved the IAC into the cab now!
For the ecomodders!: http://youtu.be/XRLtgu7iqa0
Then you might want to see my "lean burn indicator" and go for a little drive:
Lean burn - YouTube
I'll have to get some more of my wiring info up to photobucket and post it here as well...
victor.
